[GRASS-dev] Compile only wildfire modules?
Rainer M Krug
r.m.krug at gmail.com
Wed Sep 10 09:40:11 EDT 2008
On Wed, Sep 10, 2008 at 2:37 PM, Hamish <hamish_b at yahoo.com> wrote:
> Rainer:
>> I want to use the wildfire modules, and they are either EXTREMELY slow
>> (even on the demodataset) or there is something wrong with them,
>> because they seem to hang at 0% cells visited.
> It is endlessly stuck in a while loop.
> It's the second loop in r.spread/replaceHa.c, because the loop is
> launched with smaller_child = 0.
Thanks - I expected something like that. Is that corrected in the svn version?
> while ( (smaller_child <= *heap_len) &&
> (new_min_cost > heap[smaller_child].min_cost)) {
> heap[i].min_cost = heap[smaller_child].min_cost;
> heap[i].angle = heap[smaller_child].angle;
> heap[i].row = heap[smaller_child].row;
> heap[i].col = heap[smaller_child].col;
> i = smaller_child;
> smaller_child = 2 * i;
> if ((2 * i < *heap_len) &&
> (heap[2 * i].min_cost > heap[2 * i + 1].min_cost))
> smaller_child++;
>> Therefore I want to compile them with #define DEBUG enabled. At the
> Martin wrote:
>> g.gisenv set=DEBUG=5
> fyi I just migrated most of the ifdef'd DEBUGs to G_debug() (g.gisenv).
Thanks a lot.
>> moment, I am compiling the grass completely - but there must be a way
>> of compiling only the wildfire modules (or even only r.spread)?
> cd raster/wildfile/r.spread
> svn up
> make
> #insert optional install step here
OK - I'll try that.
>> How long does it take with the demomapset in demolocation (excuting the
>> script firedemo.sh manually)?
> forever.
That's what I feared.
Is there an alternative for simulating anisotropic spread ? I am using
at the moment r.cost, but that assumes isotropic spread, which I don't
have.
> the test fire simulation dataset is here:
> http://grass.osgeo.org/download/data6.php
Thanks again for all your help,
Rainer
> Hamish
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Faculty of Science
Natural Sciences Building
Private Bag X1
University of Stellenbosch
Matieland 7602
South Africa
