[GRASS-dev] Re: Testing needed for v.buffer2
Росен Матев
r.matev at gmail.com
Wed Sep 10 13:54:20 EDT 2008
Thanks for pointing out all that. Strangely, I don't get those
warnings here, probably command line switches... I think they are
fixed now.
I don't seem to have problems with centroids. Can you show me a map,
on which that occurs?
And again, please help with the busroute11 test, cause it's behaving weirdly.
Rosen Matev
On Wed, Sep 10, 2008 at 5:58 PM, Hamish <hamish_b at yahoo.com> wrote:
> Hi,
> Glad to see things coming together. Some observations:
> #include <math.h> needs to go back into e_intersect.c for fabs()
> main.c still has a call to fmin()
> functions like Vect_point_buffer2() should have prototypes declared in
> a local_proto.h file. (even if it is just temporary until it moves into
> the vector libraries)
> besides that I get these warnings which need to be addressed.
> dgraph.c: In function 'find_all_intersections':
> dgraph.c:184: warning: unused variable 'z2_'
> dgraph.c:184: warning: unused variable 'z1_'
> dgraph.c:184: warning: unused variable 'y2_'
> dgraph.c:184: warning: unused variable 'x2_'
> dgraph.c:184: warning: unused variable 'y1_'
> dgraph.c:184: warning: unused variable 'x1_'
> dgraph.c:183: warning: unused variable 'res2'
> dgraph.c: In function 'pg_create_struct':
> dgraph.c:294: warning: unused variable 'i'
> e_intersect.c: In function 'segment_intersection_2d':
> e_intersect.c:565: warning: type defaults to 'int' in declaration of 'DLEVEL'
> e_intersect.c:568: warning: unused variable 'min_by'
> e_intersect.c:568: warning: unused variable 'max_by'
> e_intersect.c:568: warning: unused variable 'min_bx'
> e_intersect.c:568: warning: unused variable 'max_bx'
> e_intersect.c:567: warning: unused variable 'min_ay'
> e_intersect.c:567: warning: unused variable 'max_ay'
> e_intersect.c:567: warning: unused variable 'min_ax'
> e_intersect.c:567: warning: unused variable 'max_ax'
> main.c: In function 'db_CatValArray_get_value_di':
> main.c:48: warning: unused variable 'val_d'
> main.c: In function 'main':
> main.c:231: warning: implicit declaration of function 'fmin'
> main.c:231: warning: incompatible implicit declaration of built-in function 'fmin'
> main.c:339: warning: incompatible implicit declaration of built-in function 'fmin'
> main.c:346: warning: implicit declaration of function 'Vect_point_buffer2'
> main.c:353: warning: implicit declaration of function 'Vect_line_buffer2'
> main.c:393: warning: incompatible implicit declaration of built-in function 'fmin'
> main.c:399: warning: implicit declaration of function 'Vect_area_buffer2'
> main.c:124: warning: unused variable 'size_val_int'
> main.c:112: warning: unused variable 'debug'
> main.c:111: warning: unused variable 'dtmp'
> vlib_buffer.c: In function 'angular_tolerance':
> vlib_buffer.c:130: warning: unused variable 'b'
> vlib_buffer.c: In function 'parallel_line':
> vlib_buffer.c:159: warning: unused variable 'r'
> vlib_buffer.c:159: warning: unused variable 'sina'
> vlib_buffer.c:159: warning: unused variable 'cosa'
> vlib_buffer.c: In function 'convolution_line':
> vlib_buffer.c:310: warning: unused variable 'r'
> vlib_buffer.c:310: warning: unused variable 'sina'
> vlib_buffer.c:310: warning: unused variable 'cosa'
> vlib_buffer.c:459:15: warning: "/*" within comment
> vlib_buffer.c: In function 'extract_contour':
> vlib_buffer.c:451: warning: unused variable 'i'
> vlib_buffer.c: In function 'extract_outer_contour':
> vlib_buffer.c:581: warning: unused variable 'ta'
> vlib_buffer.c: In function 'Vect_area_buffer2':
> vlib_buffer.c:911: warning: unused variable 'max'
> vlib_buffer.c:908: warning: unused variable 'winding'
> vlib_buffer.c:908: warning: unused variable 'res'
> the unused variables are just noise, but too much noise can hide a signal.
> I ran the module on the Spearfish test dataset roads layer, all seemed to
> work well. I noticed that the resulting areas were missing centroids and
> the number of lines shrunk considerably with v.build.polylines.
> regards,
> Hamish
