[GRASS-dev] wxGUI vedit dropped
Moritz Lennert mlennert at club.worldonline.be
Thu Sep 11 03:24:10 EDT 2008
On 11/09/08 08:11, Martin Landa wrote:
> Hi,
> currently you can choose from two components of vector digitizer --
> vedit and vdigit. Vedit calls directly v.edit command which slows down
> every action, Vdigit uses C++ extension. Vedit component has been part
> of the development. It this moment I would suggest to drop this
> component. At the end code will be more readable and only one
> component will be tested.
> http://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/gui_modules/vdigit.py#L242
> http://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/gui_modules/vdigit.py#L783
> If you agree I will remove vedit component during next week.
Are there any functionalities in the vedit version which are not
available in the vdigit one ?
Moritz
