[GRASS-dev] wxGUI vedit dropped
Martin Landa landa.martin at gmail.com
Thu Sep 11 02:11:03 EDT 2008
currently you can choose from two components of vector digitizer --
vedit and vdigit. Vedit calls directly v.edit command which slows down
every action, Vdigit uses C++ extension. Vedit component has been part
of the development. It this moment I would suggest to drop this
component. At the end code will be more readable and only one
component will be tested.
http://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/gui_modules/vdigit.py#L242
http://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/gui_modules/vdigit.py#L783
If you agree I will remove vedit component during next week.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
