[GRASS-dev] new g.mremove doesn't compile on Mac OS X
Michael Barton michael.barton at asu.edu
Sat Sep 13 15:01:05 EDT 2008
I just did an update and compile for OS X (10.5)
The new C version of g.mremove doesn't compile. Here are the errors.
cmb-MBP-2:nviz cmbarton$  cd /Users/cmbarton/grass_dev/grass6_src/
general/g.mremove
cmb-MBP-2:g.mremove cmbarton$ make
gcc -I/Users/cmbarton/grass_dev/grass6_src/dist.i386-apple-darwin9.4.0/
include  -arch i386 -Os -g       -DPACKAGE=\""grassmods"\"  -I/Users/
cmbarton/grass_dev/grass6_src/dist.i386-apple-darwin9.4.0/include -o
OBJ.i386-apple-darwin9.4.0/do_remove.o -c do_remove.c
In file included from /Users/cmbarton/grass_dev/grass6_src/dist.i386-
apple-darwin9.4.0/include/grass/vect/digit.h:3,
apple-darwin9.4.0/include/grass/Vect.h:4,
                  from do_remove.c:2:
include/grass/vect/dig_structs.h:22:21: error: ogr_api.h: No such file
or directory
                  from do_remove.c:2:
include/grass/vect/dig_structs.h:175: error: syntax error before
‘OGRDataSourceH’
include/grass/vect/dig_structs.h:175: warning: no semicolon at end of
struct or union
include/grass/vect/dig_structs.h:176: warning: data definition has no
type or storage class
include/grass/vect/dig_structs.h:191: error: syntax error before
‘feature_cache’
include/grass/vect/dig_structs.h:191: warning: data definition has no
include/grass/vect/dig_structs.h:214: error: syntax error before ‘}’
token
include/grass/vect/dig_structs.h:219: error: field ‘ogr’ has
incomplete type
make: *** [OBJ.i386-apple-darwin9.4.0/do_remove.o] Error 1
Michael
