[GRASS-dev] nviz compile errors on Mac OS X
Michael Barton
michael.barton at asu.edu
Sun Sep 14 16:00:00 EDT 2008
I tried it without debug and still got the same kind of crash.
Attached is the latest crash log: --with-x --without-tcltk and without
the -g flags.
Michael
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20080914/ed970962/Python_2008-09-14-125829_cmb-MBP-2-0001.obj
On Sep 14, 2008, at 11:36 AM, William Kyngesburye wrote:
> On Sep 14, 2008, at 1:22 PM, Michael Barton wrote:
>> I went ahead and installed PyOpenGL, recompiled ../lib/nviz and ../
>> wxpython/nviz.
> Nothing binary in PyOpenGL, so no need to recompile.
>> Same result. I'm glad that you're getting partway there on the
>> Mini, but not sure what else I need to do to duplicate your setup.
>> I'm including my compile ritual below for comparison. Note, I AM
>> building the TclTk GUI too, but that shouldn't matter.
>> Michael
>> export CFLAGS="-arch i386 -Os -g"
>> export LDFLAGS="-arch i386 -Os -g"
> If below doesn't help, try without the -g flag?
>> --with-wxwidgets=/usr/local/lib/wxPython-unicode-2.8.8.1/bin/wx-
>> config --with-wxwidgets=/usr/bin/wx-config
> Um, you should only use the /usr/local one. I'm guessing that the
> 2nd --with-wxwidgets completely overrides the first.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Those people who most want to rule people are, ipso-facto, those
> least suited to do it."
> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
