[GRASS-dev] nviz compile errors on Mac OS X
Michael Barton
michael.barton at asu.edu
Sat Sep 13 21:07:47 EDT 2008
I just tried this and nviz compiles. Now both vdigit and nviz compile.
But nviz doesn't work yet. It crashes Python when I select it. Any
idea how to find out what the error is? Will the report to Apple be
useful?
Michael
On Sep 13, 2008, at 12:49 PM, William Kyngesburye wrote:
> On Sep 13, 2008, at 1:59 PM, Michael Barton wrote:
>> Just did an update and compile of develbranch_6
>> ../lib/nviz compiles but ../gui/wxpython/nviz does not. Here are
>> the errors.
>> grass6_wxnviz_wrap.cpp: In static member function ‘static int
>> swig::traits_asptr_stdseq<Seq, T>::asptr(PyObject*, Seq**)’:
>> grass6_wxnviz_wrap.cpp:3889: error: expected unqualified-id before
>> ‘?’ token
> I just hit this also in my Mini compile test. Martin - that #undef
> fix for nviz.i should be:
> %module grass6_wxnviz
> #include "nviz.h"
> #include <grass/gsurf.h>
> #include <grass/gstypes.h>
> #undef check
> ie, inside the braces. Otherwise it doesn't get inserted into the
> generated wrapper source.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "I ache, therefore I am. Or in my case - I am, therefore I ache."
> - Marvin
