[GRASS-dev] nviz compile errors on Mac OS X
Glynn Clements
glynn at gclements.plus.com
Sun Sep 14 04:49:18 EDT 2008
Michael Barton wrote:
> Attached is the crashlog
> There is something a bit odd with the header information. It has the
> right path for my MacPython version installation, but the version is
> for the Apple system Python. I wonder if this is along the same lines
> as the issue that was killing vdigit.
If it's mixing binaries for different Python versions, that isn't
going to work.
Certainly, the crash dump is consistent with that scenario, i.e.
crashing while dlopen()ing a shared library.
Remind me again: why can't you use the system Python? Is wxPython not
available for the system Python?
> Binary Images:
> 0x13fe7000 - 0x13fe7ff1 +libXau.6.dylib ??? (???) <af0fefbbf38efd4df94bedea64d5019d> /usr/X11/lib/libXau.6.dylib
> 0x14758000 - 0x1475dffc +libSM.6.dylib ??? (???) <da2933333b791701efb3878166c35435> /usr/X11/lib/libSM.6.dylib
> 0x147e6000 - 0x147f7ff7 +libICE.6.dylib ??? (???) <68bd0c63da68b6c30273693c7b775c4f> /usr/X11/lib/libICE.6.dylib
> 0x16012000 - 0x1605dff8 +libXt.6.dylib ??? (???) <09f2a2bdce4a8d5c4b753254435c52ea> /usr/X11/lib/libXt.6.dylib
> 0x16072000 - 0x1615dfe7 +libX11.6.dylib ??? (???) <b17988a7d0432be8daf271882b9f1d45> /usr/X11/lib/libX11.6.dylib
> 0x17442000 - 0x17444fef +libXdmcp.6.dylib ??? (???) <a12913daa7d2b4efb341cb698f4182fa> /usr/X11/lib/libXdmcp.6.dylib
What are those doing in there?
More importantly:
> 0x1de6000 - 0x2483607 +libwx_macud-2.8.0.dylib ??? (???) /usr/local/lib/wxPython-unicode-2.8.8.1/lib/libwx_macud-2.8.0.dylib
> 0x1586c000 - 0x15d39fff libwx_macud-2.8.0.dylib ??? (???) <cfd5a59e5c9ce50c5a7a8888acfbd15d> /usr/lib/libwx_macud-2.8.0.dylib
Is it actually loading two different libwx_macud-2.8.0.dylib
libraries? That certainly doesn't look good.
