[GRASS-dev] nviz compile errors on Mac OS X
Michael Barton
michael.barton at asu.edu
Sun Sep 14 01:52:59 EDT 2008
Attached is the crashlog
There is something a bit odd with the header information. It has the
right path for my MacPython version installation, but the version is
for the Apple system Python. I wonder if this is along the same lines
as the issue that was killing vdigit.
Michael
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20080913/6bf2cd67/Python_2008-09-13-224821_cmb-MBP-2-0001.obj
On Sep 13, 2008, at 8:08 PM, William Kyngesburye wrote:
> On Sep 13, 2008, at 8:07 PM, Michael Barton wrote:
>> I just tried this and nviz compiles. Now both vdigit and nviz
>> compile.
>> But nviz doesn't work yet. It crashes Python when I select it. Any
>> idea how to find out what the error is? Will the report to Apple be
>> useful?
> Probably not. But this crashlog that it generates is wxactly what
> you need to find the error.
> It will have something about a thread crashing and the call trace.
> Or maybe just an error about a missing library or symbol.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "I ache, therefore I am. Or in my case - I am, therefore I ache."
> - Marvin
