[GRASS-dev] nviz compile errors on Mac OS X
Michael Barton
michael.barton at asu.edu
Sun Sep 14 12:42:39 EDT 2008
On Sep 14, 2008, at 1:49 AM, Glynn Clements wrote:
> Michael Barton wrote:
>> Attached is the crashlog
>> There is something a bit odd with the header information. It has the
>> right path for my MacPython version installation, but the version is
>> for the Apple system Python. I wonder if this is along the same lines
>> as the issue that was killing vdigit.
> If it's mixing binaries for different Python versions, that isn't
> going to work.
> Certainly, the crash dump is consistent with that scenario, i.e.
> crashing while dlopen()ing a shared library.
> Remind me again: why can't you use the system Python? Is wxPython not
> available for the system Python?
The system Python is 2.5.0 alpha. I was already using 2.5.1 before I
upgraded to OS X 10.5 with the alpha version of 2.5.0 because prior to
10.5, Apple shipped only 2.3 with its OS. I don't know why. One of the
mysteries of Cupertino.
>> Binary Images:
>> 0x13fe7000 - 0x13fe7ff1 +libXau.6.dylib ??? (???)
>> <af0fefbbf38efd4df94bedea64d5019d> /usr/X11/lib/libXau.6.dylib
>> 0x14758000 - 0x1475dffc +libSM.6.dylib ??? (???)
>> <da2933333b791701efb3878166c35435> /usr/X11/lib/libSM.6.dylib
>> 0x147e6000 - 0x147f7ff7 +libICE.6.dylib ??? (???)
>> <68bd0c63da68b6c30273693c7b775c4f> /usr/X11/lib/libICE.6.dylib
>> 0x16012000 - 0x1605dff8 +libXt.6.dylib ??? (???)
>> <09f2a2bdce4a8d5c4b753254435c52ea> /usr/X11/lib/libXt.6.dylib
>> 0x16072000 - 0x1615dfe7 +libX11.6.dylib ??? (???)
>> <b17988a7d0432be8daf271882b9f1d45> /usr/X11/lib/libX11.6.dylib
>> 0x17442000 - 0x17444fef +libXdmcp.6.dylib ??? (???)
>> <a12913daa7d2b4efb341cb698f4182fa> /usr/X11/lib/libXdmcp.6.dylib
> What are those doing in there?
There should be no x11 calls. Is this something hard coded for Linux
somewhere?
> More importantly:
>> 0x1de6000 - 0x2483607 +libwx_macud-2.8.0.dylib ??? (???) /usr/
>> local/lib/wxPython-unicode-2.8.8.1/lib/libwx_macud-2.8.0.dylib
The date on these libraries seem to be associate them with the system
Python install
>> 0x1586c000 - 0x15d39fff libwx_macud-2.8.0.dylib ??? (???)
>> <cfd5a59e5c9ce50c5a7a8888acfbd15d> /usr/lib/libwx_macud-2.8.0.dylib
These are associated with the installation of the current wxPython 2.8.8
> Is it actually loading two different libwx_macud-2.8.0.dylib
> libraries? That certainly doesn't look good.
> Glynn Clements <glynn at gclements.plus.com>
