[GRASS-dev] nviz compile errors on Mac OS X
Michael Barton michael.barton at asu.edu
Sun Sep 14 14:22:39 EDT 2008
I went ahead and installed PyOpenGL, recompiled ../lib/nviz and ../
wxpython/nviz.
Same result. I'm glad that you're getting partway there on the Mini,
but not sure what else I need to do to duplicate your setup. I'm
including my compile ritual below for comparison. Note, I AM building
the TclTk GUI too, but that shouldn't matter.
Michael
export CFLAGS="-arch i386 -Os -g"
export LDFLAGS="-arch i386 -Os -g"
export NAD2BIN=/Library/Frameworks/PROJ.framework/Programs/nad2bin
./configure --with-freetype --with-freetype-includes="/Library/
Frameworks/FreeType.framework/unix/include/freetype2 /Library/
Frameworks/FreeType.framework/unix/include" --with-freetype-libs=/
Library/Frameworks/FreeType.framework/unix/lib --with-gdal=/Library/
Frameworks/GDAL.framework/Programs/gdal-config --with-proj --with-proj-
includes=/Library/Frameworks/PROJ.framework/unix/include --with-proj-
libs=/Library/Frameworks/PROJ.framework/unix/lib --with-proj-share=/
Library/Frameworks/PROJ.framework/Resources/proj --with-jpeg-includes=/
Library/Frameworks/UnixImageIO.framework/unix/include --with-jpeg-
libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-png-
includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-
png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-
tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/include --
with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --
without-postgres --without-mysql --with-odbc --with-sqlite --with-
sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib --with-
sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/include --
with-fftw-includes=/Library/Frameworks/FFTW3.framework/unix/include --
with-fftw-libs=/Library/Frameworks/FFTW3.framework/unix/lib --with-x --
with-cxx --with-opengl=aqua --without-readline --prefix=/Applications/
GRASS --enable-macosx-app --with-wxwidgets=/usr/local/lib/wxPython-
unicode-2.8.8.1/bin/wx-config --with-wxwidgets=/usr/bin/wx-config --
with-tcltk-includes="/Library/Frameworks/Tcl.framework/Headers /
Library/Frameworks/Tk.framework/Headers /Library/Frameworks/
Tk.framework/PrivateHeaders"
after configure, *before* make, edit include/make/platform.make:
TCLTKLIBS = -framework Tcl -framework Tk
____________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
On Sep 14, 2008, at 9:07 AM, William Kyngesburye wrote:
> On Sep 14, 2008, at 12:52 AM, Michael Barton wrote:
>> Attached is the crashlog
>> There is something a bit odd with the header information. It has
>> the right path for my MacPython version installation, but the
>> version is for the Apple system Python. I wonder if this is along
>> the same lines as the issue that was killing vdigit.
>> Michael
> For some reason the MacPython has always been built with that 2.5a0
> version number, no matter what 2.5.x version it really is.  So
> everything there is macpython.
> It looks like it's crashing trying to load a module, but it's not
> saying what it is.
> *Update*
> Test on Mini: nviz sortof runs (no crash) - the "Please wait,
> loading data" window just sits there and the display remains 2D, but
> there are a palette and quit (nviz) tool buttons.  I can "quit" nviz
> and the please wait dialog goes away.
> In addition to the other macpython + wx I mentioned, I installed
> PyOpenGl 3.0.0b5.
> I get the same when I compile for the system python.
> How did you configure GRASS?  The relevant options I used are:
> --with-x
> --with-python
> --with-opengl=aqua
> --without-tcltk
> --with-wxwidgets=/usr/local/lib/wxPython-unicode-2.8.8.1/bin/wx-config
> I didn't use a path for python (not needed).
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "I ache, therefore I am.  Or in my case - I am, therefore I ache."
> - Marvin
