[GRASS-dev] nviz compile errors on Mac OS X
William Kyngesburye
woklist at kyngchaos.com
Sun Sep 14 14:36:24 EDT 2008
On Sep 14, 2008, at 1:22 PM, Michael Barton wrote:
> I went ahead and installed PyOpenGL, recompiled ../lib/nviz and ../
> wxpython/nviz.
Nothing binary in PyOpenGL, so no need to recompile.
> Same result. I'm glad that you're getting partway there on the Mini,
> but not sure what else I need to do to duplicate your setup. I'm
> including my compile ritual below for comparison. Note, I AM
> building the TclTk GUI too, but that shouldn't matter.
> Michael
> export CFLAGS="-arch i386 -Os -g"
> export LDFLAGS="-arch i386 -Os -g"
If below doesn't help, try without the -g flag?
> --with-wxwidgets=/usr/local/lib/wxPython-unicode-2.8.8.1/bin/wx-
> config --with-wxwidgets=/usr/bin/wx-config
Um, you should only use the /usr/local one. I'm guessing that the 2nd
--with-wxwidgets completely overrides the first.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Those people who most want to rule people are, ipso-facto, those
least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
