[GRASS-dev] nviz compile errors on Mac OS X
Michael Barton
michael.barton at asu.edu
Sun Sep 14 16:06:51 EDT 2008
On Sep 14, 2008, at 1:02 PM, William Kyngesburye wrote:
> On Sep 14, 2008, at 2:22 PM, Michael Barton wrote:
>> Typo fixed.
>> Recompiled (did make distclean between each compilation just to
>> make sure that nothing lurking in a previous build could cause a
>> problem) using: --without-x --without-tcltk AND --with-x --without-
>> tcltk
>> Still no go. I'm attaching crash logs. I am also noticing that
>> every make and make install causes a r.terraflow crash--even though
>> I've not launched r.terraflow. I'm not sure what this is about, but
>> note that the problematic wxPython modules and r.terraflow all use C
>> I'm attaching the r.terraflow crash log too, in case it holds a clue.
> I get those also. It hasn't bothered me enough yet to look into it.
>> Michael
>> <Python_without-x_without-tcltk.crash>
>> <Python_with-x_without-tcltk.crash>
>> <r.terraflow_2008-09-14-121541_cmb-MBP-2.crash>
> Still some X11 libs in there, so it's probably something else
> outside GRASS loading them (something in python or wx?). Dead end.
> Though I do see that the wxnviz makefile unconditionally links the
> X11 libraries. Maybe something else to move to the non-OSX
> EXTRA_LIBS - since OSX will always be using an Aqua python (I
> suppose it's theoretically possibly to compile GRASS on OSX with all
> X11-based python and wxpython) - or conditionalize on the OpenGL
> flag (whether it's aqua or X11 or Windows).
> On further inspection of the crashlog, I think it's the
> _grass6_wxnviz.so that it's choking on (makes sense). I see that
> libgrass_nviz is loaded in the binary images section, but not
> _grass6_wxnviz.so (_grass6_wxnviz.so and nviz2 are the only things
> that link libgrass_nviz). So it was in the middle of loading it and
> got libgrass_nviz loaded, then crash. From there I'm at a loss.
That's the file created with swig. Same kind of file that vdigit has
been choking on.
Michael
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> All generalizations are dangerous, even this one.
