[GRASS-dev] nviz compile errors on Mac OS X
William Kyngesburye woklist at kyngchaos.com
Sun Sep 14 16:25:07 EDT 2008
On Sep 14, 2008, at 3:02 PM, William Kyngesburye wrote:
> On further inspection of the crashlog, I think it's the
> _grass6_wxnviz.so that it's choking on (makes sense).  I see that
> libgrass_nviz is loaded in the binary images section, but not
> _grass6_wxnviz.so (_grass6_wxnviz.so and nviz2 are the only things
> that link libgrass_nviz).  So it was in the middle of loading it and
> got libgrass_nviz loaded, then crash.  From there I'm at a loss.
Here's an odd thought - permissions.  When python source is loaded,
python automatically attempts to compile bytecode as .pyc, alongside
the source.  I don't know what python does if it can't write these
files due to lack of permissions.
When you sudo make install, you then don't have write permissions in
the GRASS.app folders.
I've been running my GRASS tests in an uninstalled copy, with this
procedure:
make
make bindist
the OSX bindist creates an installer package, and *also* leaves behind
the assembled application in macosx/dist.  Try this.
Otherwise, I'm grasping at straws now.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Oh, look, I seem to have fallen down a deep, dark hole.  Now what
does that remind me of?  Ah, yes - life."
- Marvin
