[GRASS-dev] nviz compile errors on Mac OS X
Michael Barton
michael.barton at asu.edu
Sun Sep 14 16:38:43 EDT 2008
On Sep 14, 2008, at 1:25 PM, William Kyngesburye wrote:
> On Sep 14, 2008, at 3:02 PM, William Kyngesburye wrote:
>> On further inspection of the crashlog, I think it's the
>> _grass6_wxnviz.so that it's choking on (makes sense). I see that
>> libgrass_nviz is loaded in the binary images section, but not
>> _grass6_wxnviz.so (_grass6_wxnviz.so and nviz2 are the only things
>> that link libgrass_nviz). So it was in the middle of loading it
>> and got libgrass_nviz loaded, then crash. From there I'm at a loss.
> Here's an odd thought - permissions. When python source is loaded,
> python automatically attempts to compile bytecode as .pyc, alongside
> the source. I don't know what python does if it can't write these
> files due to lack of permissions.
> When you sudo make install, you then don't have write permissions in
> the GRASS.app folders.
> I've been running my GRASS tests in an uninstalled copy, with this
> procedure:
> make
> make bindist
> the OSX bindist creates an installer package, and *also* leaves
> behind the assembled application in macosx/dist. Try this.
Tried it. Got a warning...
2008-09-14 13:34:55.327 packagemaker[52382:60b] relocate: (null) 0
Warning: Could not preserve resource forks because /Tools/
SplitForks could not be found.
rm -f "GRASS-6.4.pkg/Contents/Resources/TokenDefinitions.plist"
Otherwise it seems to install.
But nviz doesn't work
> Otherwise, I'm grasping at straws now.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Oh, look, I seem to have fallen down a deep, dark hole. Now what
> does that remind me of? Ah, yes - life."
> - Marvin
