[GRASS-dev] nviz compile errors on Mac OS X
Michael Barton michael.barton at asu.edu
Mon Sep 15 00:13:39 EDT 2008
On Sep 14, 2008, at 5:38 PM, William Kyngesburye wrote:
> On Sep 14, 2008, at 6:26 PM, Michael Barton wrote:
>> It's definitely a compile issue. Your version works just as you
>> describe it--AND vdigit works too.
> hmmmmm
> rrrrgggghhhh
> The only other thing I can think of that I do a little different is
> maybe the OSX build target.  I set the MACOSX_DEPLOYMENT_TARGET to
> 10.5 (or 10.4 for my Tiger builds).  The default is 10.2 or 10.3 I
> think.  There are some differences in compilation depending on this
> value, though I think it's mostly API differences not compiler
> behavior.  Python code wants you to match what was used when it was
> compiled, which is 10.4 for Macpython (though I didn't have problems
> on my Mini build).
> Try:
> export MACOSX_DEPLOYMENT_TARGET=10.5
> before configuring
Argh! That's not it either.
I'm getting more and more convinced that it is something to do with
swig. I installed mine a long time ago. I know that swig stable hasn't
changed in several years, but possibly I need to reinstall it.
Michael
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "This is a question about the past, is it? ... How can I tell that
> the past isn't a fiction designed to account for the discrepancy
> between my immediate physical sensations and my state of mind?"
> - The Ruler of the Universe
