[GRASS-dev] [GRASS GIS] #308: Compiler error while building python swig
Mon Sep 15 03:36:19 EDT 2008
GRASS GIS wrote:
>  Adding a _Color_Value_ struct helps it get past the preprocessor stage,
>  but
>  then the compliation fails:
>  python_grass6_wrap.c:2945: warning: function declaration isn't a prototype
>  python_grass6_wrap.c: In function '_wrap__Color_Value__value_set':
>  python_grass6_wrap.c:5228: error: invalid application of 'sizeof' to
>  incomplete type 'struct _Color_Value_'
At this point, it may help if you post (or attach to the ticket) your
modified version.
