[GRASS-dev] Re: [GRASS GIS] #308: Compiler error while building
python swig
trac at osgeo.org
Tue Sep 16 01:15:30 EDT 2008
#308: Compiler error while building python swig
Reporter: cgsbob | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: SWIG (all bindings) | Version: svn-develbranch6
Resolution: | Keywords: python swig
Platform: Unspecified | Cpu: Unspecified
Comment (by hamish):
Glynn wrote:
> At this point, it may help if you post (or attach to the ticket)
> your modified version.
That was with the _Color_Value_ struct as given in comment:15 to the
ticket.
I have now made an attempt at automatically expanding the struct in gis.h
to avoid the problem. Now py/swig builds without error and we are finally
using an up to date copy of gis.h.
SVN r33454 thru r33456. Improvements to the expansion method are most
welcome.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/308#comment:17>
