[GRASS-dev] nviz compile errors on Mac OS X
Michael Barton michael.barton at asu.edu
Mon Sep 15 10:20:08 EDT 2008
On Sep 15, 2008, at 1:05 AM, Glynn Clements wrote:
> William Kyngesburye wrote:
>>>> In addition to the other macpython + wx I mentioned, I installed
>>>> PyOpenGl 3.0.0b5.
>>> This shouldn't be necessary to run OpenGL but maybe Martin is using
>>> it for something.
>> nviz wouldn't run without it.
> Huh? What happens when you try?
wxNviz uses the GLCanvas, which requires PyOpenGL. Note that wxPython
does not need PyOpenGL, but GLCanvas does.
Michael
