[GRASS-dev] nviz compile errors on Mac OS X
Glynn Clements
glynn at gclements.plus.com
Tue Sep 16 02:34:01 EDT 2008
Michael Barton wrote:
> >>>> In addition to the other macpython + wx I mentioned, I installed
> >>>> PyOpenGl 3.0.0b5.
> >>> This shouldn't be necessary to run OpenGL but maybe Martin is using
> >>> it for something.
> >> nviz wouldn't run without it.
> > Huh? What happens when you try?
> wxNviz uses the GLCanvas, which requires PyOpenGL. Note that wxPython
> does not need PyOpenGL, but GLCanvas does.
Odd; I don't see an "import" statement for it in wx/glcanvas.py, nor
anything in the code which appears to use it.
Have you actually checked that it needs PyOpenGL?
