[GRASS-dev] nviz compile errors on Mac OS X
Michael Barton michael.barton at asu.edu
Tue Sep 16 14:29:55 EDT 2008
On Sep 15, 2008, at 11:34 PM, Glynn Clements wrote:
> Michael Barton wrote:
>>>>>> In addition to the other macpython + wx I mentioned, I installed
>>>>>> PyOpenGl 3.0.0b5.
>>>>> This shouldn't be necessary to run OpenGL but maybe Martin is
>>>>> using
>>>>> it for something.
>>>> nviz wouldn't run without it.
>>> Huh? What happens when you try?
>> wxNviz uses the GLCanvas, which requires PyOpenGL. Note that wxPython
>> does not need PyOpenGL, but GLCanvas does.
> Odd; I don't see an "import" statement for it in wx/glcanvas.py, nor
> anything in the code which appears to use it.
> Have you actually checked that it needs PyOpenGL?
Well, it *used* to require PyOpenGL. I have not checked in the current
version. Maybe it doesn't anymore, which is good. We may need to
conditionalize PyOpenGL as a dependency if older versions of wxPython
are used.
Michael
> Glynn Clements <glynn at gclements.plus.com>
