[GRASS-dev] Re: [GRASS GIS] #308: Compiler error while building python swig
GRASS GIS trac at osgeo.org
Tue Sep 16 04:46:55 EDT 2008
  Reporter:  cgsbob               |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect               |      Status:  new
  Priority:  major                |   Milestone:  6.4.0
 Component:  SWIG (all bindings)  |     Version:  svn-develbranch6
Resolution:                       |    Keywords:  python swig
  Platform:  Unspecified          |         Cpu:  Unspecified
Comment (by glynn):
 Replying to [comment:20 hamish]:
 > > Okay; I've removed the swig/python/interfaces directory.
 > > python_grass7.i now includes the headers directly (I've also
 > > un-nested the structure definitions from the headers).
 > thanks for that, but the problem AFAICT was not nested headers, it's
 with
 struct { "..." } a, b;
 > needing to be like:
 struct { "..." } a;
 struct { "..." } b;
 The problem occurs when a nested definition is used for multiple fields.
 It is solved by extracting the definition then using the tag when defining
 the field, i.e.:
 struct foo { ... };
 struct bar {
    struct foo a, b;
 There's no need to repeat the definition for each field.
Ticket URL: <http://trac.osgeo.org/grass/ticket/308#comment:22>
