[GRASS-dev] Re: [GRASS GIS] #308: Compiler error while building
python swig
trac at osgeo.org
Tue Sep 16 23:54:46 EDT 2008
#308: Compiler error while building python swig
Reporter: cgsbob | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: SWIG (all bindings) | Version: svn-develbranch6
Resolution: | Keywords: python swig
Platform: Unspecified | Cpu: Unspecified
Comment (by hamish):
Glynn:
> The problem occurs when a nested definition is used for multiple
> fields. It is solved by extracting the definition then using the
> tag when defining the field,
Ok. I don't know why it didn't work the first time I tried untangling
those structs but with the latest edits to SVN it all works now.
Great. Backported to devbr6.
One last thing I'd like to figure out before closing this bug:
"python test.py" should be run by the Makefile. Besides testing that it
all works this compiles the .pyc version while we know we have write
access to the dir. If we wait until after install and let it happen at
runtime, it is likely that the user won't have write permissions to the
dir and it will have to be recompiled in memory every time the user uses
the lib.
For python_grass[67].py the test must be run in a fake grass session (same
as the man pages) but I'm not sure how to do that in the Makefile.
For NumPtr/build/lib.linux-i686-2.4/NumPtr.py I am not sure how to
generalize the $ARCH. Otherwise it is easy to add "python build/lib.linux-
i686-2.4/test.py" to the Makefile there to generate the .pyc.
thanks,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/308#comment:23>
