[GRASS-dev] Re: Problem when loading GRASS 6 raster with large integer values into R via r.out.bin
Roger Bivand Roger.Bivand at nhh.no
Thu Sep 18 17:01:23 EDT 2008
Roger Bivand <Roger.Bivand <at> nhh.no> writes:
> Markus Neteler <neteler <at> osgeo.org> writes:
> > On Wed, Sep 17, 2008 at 10:49 AM, Roger Bivand <Roger.Bivand <at>
> > means:
> > - the GDAL plugin is no option here since it does not respect current
> >   region settings
> > - r.out.gdal is good since it does the job (AFAIK). Written in C
> I can revisit this in relation to using r.out.gdal for GRASS >= 6.3
> instead of r.out.bin - in which case I can make r.out.gdal use 32
> bits for integers and 64 bits for float/doubles.
Committed on R-spatial sourceforge CVS, new flag useGDAL=FALSE for now
default, uses Int32 for CELL, so maybe could be tried to see if it works
better than r.out.bin.
If it does, I'll change writeRAST6() too, change the default to TRUE, and
release.
Roger
> Roger
> > Perhaps you mean r.out.gdal.sh?
> > Best
> > Markus
