[GRASS-dev] grassaddons/raster/r.rast4d: SQL type changes question
Markus Neteler
neteler at osgeo.org
Wed Sep 24 18:21:33 EDT 2008
I would like to submit the attached diff to addons but I am unsure about
side effects. Scope: make r.rast4d less dependent on SQLite but also
PostgreSQL compliant (so that the user can just switch in the config
script between both systems).
essentially:
CLOB -> TEXT
NUMERIC(25,15) -> NUMERIC
NUMERIC(15,10) -> NUMERIC
I wonder about the CLOB change in particular but I don't have enough
experience to decide.
thanks
Markus
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20080925/1665bad1/r_rast4d_types_declarations-0001.obj
