[GRASS-dev] Addons: r.horizon single point mode segfault
Markus Neteler
neteler at osgeo.org
Fri Sep 26 02:47:39 EDT 2008
On Fri, Sep 26, 2008 at 3:50 AM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> I tried to use r.horizon in single point mode but it segfaults:
>> (gdb) r elevation.dem step=30 direction=15 bufferzone=200
> Spearfish?
Yes.
>> coord=-103.75026822,44.43602767
> Hmm.
>> 1101 z_orig = zp = z[yindex][xindex];
>> xindex = -19662
>> yindex = -163781
>> What could be the problem here?
>> xcoord = -103.75026822
>> ycoord = 44.436027670000001
> This:
> 194 stepx = cellhd.ew_res;
> 195 stepy = cellhd.ns_res;
> 215 xmin = cellhd.west;
> 216 ymin = cellhd.south;
> 461 xmin = new_cellhd.west;
> 462 ymin = new_cellhd.south;
> 1073 xindex = (int)((xcoord - xmin) / stepx);
> 1074 yindex = (int)((ycoord - ymin) / stepy);
> suggests that coord= is supposed to be cartographic coordinates, but
> coord=-103,44 is way outside of the Spearfish region (~600000,4920000).
Good point. I gave LL coords to the module.
This works:
GRASS 6.4.svn (spearfish60):~ > g.region -c
center easting: 599505.000000
center northing: 4921010.000000
GRASS 6.4.svn (spearfish60):~ > r.horizon elevation.dem step=30
direction=15 bufferzone=200 coord=599505.0,4921010.0
15.000000, 0.408906
45.000000, 0.140486
75.000000, 0.000000
105.000000, 0.000000
135.000000, 0.158644
165.000000, 0.260598
195.000000, 0.303381
225.000000, 0.318726
255.000000, 0.237845
285.000000, 0.276001
315.000000, 0.368949
345.000000, 0.408906
So everything fine here.
thanks
Markus
