[GRASS-dev] slow $PROMPT_COMMAND
Glynn Clements
glynn at gclements.plus.com
Fri Sep 26 12:23:42 EDT 2008
Glynn Clements wrote:
> > Could the GRASS-GDAL-Plugin-autoload mechanism adapted
> > somehow (of course that's the reverse direction)? The GRASS plugin
> > is only loaded on demand. This would slow down the command using
> > it but for r.external and r.{in,out}.gdal it might be irrelevant since
> > usually performed only one time.
> Loading GDAL dynamically shouldn't be too much of a problem; r.in.gdal
> used to do this (gdalbridge.[ch]), although I wouldn't use that
> specific code).
> I'll look into it.
Done in r33559.
By default, GDAL is loaded at run-time, but you can force direct
linking with "make GDAL_DYNAMIC=", or disable the GDAL support
altogether with "make GDAL_LINK=".
With run-time loading, the g.gisenv timings are comparable to the
non-GDAL case.
