[GRASS-dev] Addons: r.sun2 segfault with -s
Markus Neteler neteler at osgeo.org
Fri Sep 26 03:04:01 EDT 2008
hi again,
while r.horizon is working in both modes, some troubles with r.sun2:
Spearfish data set:
g.region rast=elevation.dem -p
# took these values from the manuak page:
r.horizon elevation.dem step=30 e_buff=20 horizon=horangle dist=0.7 \
              maxdistance=4000
r.sun2 -s elevation.dem horizon=horangle aspin=aspect slopein=slope \
          glob_rad=global_rad day=180 time=14
Mode 1: instantaneous solar incidence angle & irradiance using a set local
time
Segmentation fault
GRASS 6.4.svn (spearfish60):~/grass64 > gdb r.sun2
GNU gdb 6.6-3mdv2008.0 (Mandriva Linux release 2008.0)
This GDB was configured as "x86_64-mandriva-linux-gnu"...
Using host libthread_db library "/lib64/libthread_db.so.1".
(gdb) r -s elevation.dem horizon=horangle aspin=aspect slopein=slope
time
  0%
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 46932323701152 (LWP 7370)]
0x0000000000409afc in lumcline2 (sungeom=0x7fff6a09d610,
sunVarGeom=0x7fff6a09d5b0, sunSlopeGeom=0x7fff6a09d580,
   gridGeom=0x7fff6a09d720, horizonpointer=0x0) at rsunlib.c:383
383                             horizonHeight = invScale*(
I assume that horizonpointer=0x0 is no good thing.
Without -s it works.
Any ideas,
Markus
