[GRASS-dev] Re: [GRASS GIS] #520: r.terraflow/iostream does not
respect STREAM_DIR option
trac at osgeo.org
Wed Apr 8 20:41:59 EDT 2009
#520: r.terraflow/iostream does not respect STREAM_DIR option
Reporter: mmetz | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Raster | Version: svn-develbranch6
Resolution: | Keywords:
Platform: All | Cpu: All
Comment (by glynn):
Replying to [comment:11 adanner]:
> Hmm. /var/tmp/flowStream is a file but streamdir->answer is supposed to
be a directory. "flowStream" should be appended to streamdir->answer. Can
you use strcat or is there a G_? function for that?
We normally use sprintf(), e.g.:
char path[GPATH_MAX];
sprintf(path, "%s/flowStream", streamdir->answer);
Ticket URL: <http://trac.osgeo.org/grass/ticket/520#comment:12>
