[GRASS-dev] [GRASS GIS] #550: v.to.3d: column name case sensitive
GRASS GIS trac at osgeo.org
Wed Apr 8 23:10:36 EDT 2009
 Reporter:  hamish   |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect   |      Status:  new
 Priority:  minor    |   Milestone:  6.4.0
Component:  Vector   |     Version:  svn-develbranch6
 Keywords:  v.to.3d  |    Platform:  Linux
      Cpu:  x86-32   |
 just had need to use v.to.3d for the first time. It's nice!
 minor issue: the imported shapefile created columns named as:
 INTEGER|cat
 DOUBLE PRECISION|EASTING
 DOUBLE PRECISION|NORTHING
 DOUBLE PRECISION|ELEVATION
 (using dbf driver)
 I tried to use 'v.to.3d column=elevation' but it exited with the message:
 ERROR: Column <elevation> not found in table <bathymetry_point>
 It needed to see 'column=ELEVATION'. G_strcasecmp() or tolower() needed?
 also that failure left an empty map behind.
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/550>
