[GRASS-dev] [GRASS GIS] #550: v.to.3d: column name case sensitive
Moritz Lennert
mlennert at club.worldonline.be
Thu Apr 9 05:17:55 EDT 2009
> Reporter: hamish | Owner: grass-dev at lists.osgeo.org
> Type: defect | Status: new
> Priority: minor | Milestone: 6.4.0
> Component: Vector | Version: svn-develbranch6
> Keywords: v.to.3d | Platform: Linux
> Cpu: x86-32 |
> Hi,
> just had need to use v.to.3d for the first time. It's nice!
> minor issue: the imported shapefile created columns named as:
> INTEGER|cat
> DOUBLE PRECISION|EASTING
> DOUBLE PRECISION|NORTHING
> DOUBLE PRECISION|ELEVATION
> (using dbf driver)
> I tried to use 'v.to.3d column=elevation' but it exited with the message:
> ERROR: Column <elevation> not found in table <bathymetry_point>
> It needed to see 'column=ELEVATION'. G_strcasecmp() or tolower() needed?
Are column names case insensitive in all db backends ?
Moritz
