[GRASS-dev] make install targets?
Markus Neteler neteler at osgeo.org
Fri Apr 10 09:03:18 EDT 2009
On Sun, Mar 30, 2008 at 7:09 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> (copied here from grass-user)
>> Related to below problem, would it be possible to add a
>>  make install
>> target to all Makefiles?
> There are many cases which would require a custom install target (as
> opposed to a generic target in e.g. Rules.make), as a generic target
> wouldn't know which files it's supposed to be installing.
> Realistically, this should wait for 6.4/7.x, when the build system
> will get cleaned up to make it easier to build modules against an
> installed version of GRASS.
I would still appreciate a generic "make install" - is that now feasible?
Markus
