[GRASS-dev] make install targets?
Markus Neteler neteler at osgeo.org
Fri Apr 10 09:32:14 EDT 2009
On Fri, Apr 10, 2009 at 3:03 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Sun, Mar 30, 2008 at 7:09 PM, Glynn Clements
>> Realistically, this should wait for 6.4/7.x, when the build system
>> will get cleaned up to make it easier to build modules against an
>> installed version of GRASS.
> I would still appreciate a generic "make install" - is that now feasible?
quick and dirty patch attached...
It fails of course for multi-target cases such as r.mapcalc.
Markus
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20090410/188829de/make_install.obj
