[GRASS-dev] Re: [GRASS GIS] #73: r.out.gdal tiff output does not
work
trac at osgeo.org
Wed Apr 15 06:59:27 EDT 2009
#73: r.out.gdal tiff output does not work
Reporter: helena | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.out.gdal, tiff
Platform: Unspecified | Cpu: Unspecified
Comment (by mmetz):
Replying to [comment:33 mlennert]:
> From the discussion, I gather that most of the problem is not a bug in
r.out.gdal, but rather the incapacity of certain viewers to display
certain types of data.
Yes, that's one problem, but a problem of the viewers. Standard image
viewers or editors like GIMP can only read type BYTE, and probably only 1
band or 3 bands in e.g. a tiff. Other types (e.g. INT16, FLOAT32) are not
supported by these image viewers. Not sure about the number of bands.
GIS software can usually both read, analyse, and visualize georeferenced
raster data as produced by r.out.gdal. The tiff colortable problem is
already solved. Some tests are in comment 13:
http://trac.osgeo.org/grass/ticket/73#comment:13
Ticket URL: <http://trac.osgeo.org/grass/ticket/73#comment:34>
