[GRASS-dev] Re: [GRASS GIS] #73: r.out.gdal tiff output does not
work
trac at osgeo.org
Wed Apr 15 07:04:18 EDT 2009
#73: r.out.gdal tiff output does not work
Reporter: helena | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.out.gdal, tiff
Platform: Unspecified | Cpu: Unspecified
Comment (by mlennert):
Replying to [comment:34 mmetz]:
> Replying to [comment:33 mlennert]:
> > From the discussion, I gather that most of the problem is not a bug in
r.out.gdal, but rather the incapacity of certain viewers to display
certain types of data.
> Yes, that's one problem, but a problem of the viewers. Standard image
viewers or editors like GIMP can only read type BYTE, and probably only 1
band or 3 bands in e.g. a tiff. Other types (e.g. INT16, FLOAT32) are not
supported by these image viewers. Not sure about the number of bands.
> GIS software can usually both read, analyse, and visualize georeferenced
raster data as produced by r.out.gdal. The tiff colortable problem is
already solved. Some tests are in comment 13:
> http://trac.osgeo.org/grass/ticket/73#comment:13
Well, is this still an open bug then, or can we close it ? Or at least
downgrade it so that it doesn't block 6.4 release ?
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/73#comment:35>
