[GRASS-dev] Re: [GRASS GIS] #73: r.out.gdal tiff output does not
work
trac at osgeo.org
Wed Apr 15 14:04:36 EDT 2009
#73: r.out.gdal tiff output does not work
Reporter: helena | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.out.gdal, tiff
Platform: Unspecified | Cpu: Unspecified
Comment (by helena):
as for me - I did not file it as critical, because I thought it was
partially
problem on my side (not using the correct options) - it was upgraded to
critical later.
I think we just need to keep around r.out.arc, r.out.tiff in case the
software
that you are trying to import the data to does not like the r.out.gdal
geotiff
as we cannot really solve other software issues with geotiff.
I also agree that the warning about possible loss of data with badly
chosen NULL
as suggested by Moritz should take care of the null problem.
All I really tried to do was convert the nc_spm raster data into something
readable
by other software tools and r.out.gdal worked but some rasters were not
readable
or came out black so it required change in color table etc. (e.g., in
ArcGIS, gimp).
We ended up using r.out.arc - and lost the color tables and projection
info but otherwise it worked fine.
I haven't tried the very latest version of r.out.gdal though.
Helena
Ticket URL: <http://trac.osgeo.org/grass/ticket/73#comment:42>
