[GRASS-dev] i.rectify still chokes on @mapset
Sat Apr 25 20:02:53 EDT 2009
Markus Neteler wrote:
> Do we need a new function to strip off the @mapset from a file name?
> Cannot find it...
G__name_is_fully_qualified() will split a qualified name into map and
mapset parts.
G__unqualified_name() does likewise, but also checks whether the
@mapset part matches a specific mapset.
In either case, you need to check the return value to determine
whether the output buffers were filled in.
