[GRASS-dev] Re: [GRASS GIS] #73: r.out.gdal tiff output does not
work
trac at osgeo.org
Thu Apr 16 12:59:42 EDT 2009
#73: r.out.gdal tiff output does not work
Reporter: helena | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.out.gdal, tiff
Platform: Unspecified | Cpu: Unspecified
Comment (by martinl):
Replying to [comment:45 mmetz]:
> r.out.gdal and r.out.tiff do two fundamentally different things and IMHO
should be neither compared nor merged.
> r.out.tiff exports an image that can be viewed with any image viewer and
looks like what you see on the grass display. The pixel values are most
likely very different from the raster map that is exported, because with
the -p flag everything is converted to Byte. Without the -p flag, the
pixel values are the colour values of the color table, not the raster
values. r.out.tiff output is thus not meant to be suitable for spatial
analysis (like a screenshot of the display).
> r.out.gdal exports data, by default with a color table for data
visualization if supported by the selected output format. The color table
is just for convenience and not needed for analysis. Data export was
successful if r.univar or some equivalent in another GIS software package
gives results identical to r.univar on the grass raster. There is a
difference between "can read the GeoTIFF" and "displays the GeoTIFF like
grass displays the original raster", therefore the display is not suitable
for testing because there are too many reasons why the display can be
different (different monitor with different settings, different OS with
different gamma, file format does not support color tables, conversion
from color rules to color tables can introduce slight modifications, other
GIS software uses different graphics engine, other GIS software can not
read embedded color table).
> Sorry for being so thick, but I want to make the point of distinguishing
images and data. Unfortunately, a .tif file can be both.
thanks for the clarification. I didn't know that. Probably it should be
explained more deeply in the manual page.
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/73#comment:46>
