[GRASS-dev] Re: [GRASS GIS] #560: WinGRASS not deleting temp ppm files from map display
GRASS GIS trac at osgeo.org
Sat Apr 18 01:10:24 EDT 2009
  Reporter:  isaacullah    |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  major         |   Milestone:  6.4.0
 Component:  Display       |     Version:  6.4.0 RCs
Resolution:                |    Keywords:  v.digit ppm temp
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by hamish):
 the only thing I can think of is that the files are still in use, so can
 not be swept up by clean_temp on exit. ?
 maybe remove the "> NUL:" from the end of the 3 calls to it in init.bat,
 rem Clean out old .tmp files from the mapset
 "%WINGISBASE%\etc\clean_temp" > NUL:
 and see if it produces an error message.
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/560#comment:1>
