[GRASS-dev] [GRASS GIS] #560: WinGRASS not deleting temp ppm files
from map display
trac at osgeo.org
Fri Apr 17 13:46:41 EDT 2009
#560: WinGRASS not deleting temp ppm files from map display
Reporter: isaacullah | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Display | Version: 6.4.0 RCs
Keywords: v.digit ppm temp | Platform: MSWindows XP
Cpu: x86-32 |
When v.digit loads, it creates it's own ppm and ppg files for the
background of the v.digit display (seperate from the ppm and ppg files
created for the regular tcltk map display). When one exits from v.digit,
those ppm and ppg stay in the .tmp directory of the mapset. When one exits
from grass, the ppm and ppg files for the map display are erased, but NOT
those created by the v.digit display. This leads to build up of files that
can eat harddrive memory. This problem was dectected on a Windows XP
machine, and has not been tested for on Linux or Mac.
Ticket URL: <http://trac.osgeo.org/grass/ticket/560>
