R: Re: [GRASS-dev] g_parser() ERROR
g_massa at libero.it g_massa at libero.it
Mon Apr 20 14:53:45 EDT 2009
>I wonder if those standard schemes should be hardcoded in a *.h file,
>with
an option to chose one of them by name or "custom" with an optional
>and
add/rename a new option called rules= to load the custom file?
>then less
work to specify path to the *.dat file...
Yes Hamish, I'm agree!
but (as you
can see) I'm not a C guru and the only solution I found is a *.h file wit n
array fore storage all texture coordinate, now  in *.dat file. This isn' t a
very smart solution . I'm looking for examples in other grass module but
without results. Could you show me any solution?
>also, what should the two
sand and clay maps look like? percent/fraction
>makeup of soil for each cell?
sand and clas has to be in 0-1 range. I will indicate in option module
Thanks
Hamish, sincerely!
gianluca
