[GRASS-dev] Re: [GRASS GIS] #565: r.colors: glibc double free or corruption with -ae
GRASS GIS trac at osgeo.org
Tue Apr 21 06:33:08 EDT 2009
  Reporter:  hamish  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect  |      Status:  new
  Priority:  minor   |   Milestone:  6.5.0
 Component:  Raster  |     Version:  svn-develbranch6
Resolution:          |    Keywords:  r.colors
  Platform:  Linux   |         Cpu:  x86-32
Changes (by hamish):
  * summary:  r.colors: glibc double free error with -ae => r.colors: glibc
Comment:
 here we go, happened again..
 GRASS65svn> r.colors map1 color=bcyr -ae
 Reading raster map <map1 at user7>...
  100%
 *** glibc detected *** double free or corruption (!prev): 0x09a3a4f8 ***
 Aborted
 G> r.univar -g map1
 n=301941
 null_cells=0
 min=-23.8941449919674
 max=1999.8932486971
 range=2023.78739368907
 mean=68.8068337965498
 mean_of_abs=71.8955312273628
 stddev=259.955255789945
 G> r.info -t map1
 datatype=DCELL
 G> gdb `which r.colors`
 (gdb) run gauss color=bcyr -ae
 Starting program: [...]/dist.i686-pc-linux-gnu/bin/r.colors map1
 color=bcyr -ae
  100%
 *** glibc detected *** double free or corruption (!prev): 0x08e40a18 ***
 Program received signal SIGABRT, Aborted.
 0xb7f18424 in __kernel_vsyscall ()
 (gdb) bt
 #0  0xb7ef0424 in __kernel_vsyscall ()
 #1  0xb7d31811 in raise () from /lib/tls/i686/cmov/libc.so.6
 #2  0xb7d32fb9 in abort () from /lib/tls/i686/cmov/libc.so.6
 #3  0xb7d66dfa in __fsetlocking () from /lib/tls/i686/cmov/libc.so.6
 #4  0xb7d6e68f in mallopt () from /lib/tls/i686/cmov/libc.so.6
 #5  0xb7d6e732 in free () from /lib/tls/i686/cmov/libc.so.6
 #6  0xb7ea2cd6 in G_free (buf=0x9b7ba18) at alloc.c:129
 #7  0x0804b386 in get_fp_stats (name=0x9b72640 "map1", mapset=0x9b72030
 "user7",
     statf=0xbfd05f94, min=3.2146326349358647, max=7.601348984183665,
 geometric=0,
     geom_abs=1) at stats.c:136
 #8  0x0804a655 in main (argc=Cannot access memory at address 0x13d8
 ) at main.c:385
 (gdb) frame 7
 "user7",
 geometric=0,
 136         G_free(dcell);
 (gdb) list
 131             }
 132         }
 133
 134         G_percent(row, nrows, 2);
 135         G_close_cell(fd);
 136         G_free(dcell);
 137     }
 (gdb) bt full
 No locals.
 "user7",
 geometric=0,
         dcell = (DCELL *) 0x9b7ba18
         row = 477
         col = 633
         nrows = 477
         ncols = 633
         fd = 7
 ) at main.c:385
         fpstats = {geometric = 0, geom_abs = 1, flip = 0, count = 1000,
   min = 3.2146326349358647, max = 7.601348984183665, stats = 0x9b7cdf0,
   total = 301941}
         overwrite = 1
         interactive = 0
 this map was created with:
 #spearfish
 g.region n=4928010 s=4913700 w=590010 e=609000 res=30
 #rows=477  cols=633   (odd number so there is a center cell)
 #latest version from grass-addons svn
 r.surf.volcano -g -r map2 peak=2000 crater=120
 but that uses r.surf.gauss which changes each time you run it. The same
 r.colors command runs to 100% with no problem with the exact same call to
 r.surf.volcano.
 r.mapcalc found no values exactly matching 0.00000 in the map.
 It consistently breaks with this map, I can .tgz it if needed.
 Here's the valgrind output:
 G> CMD="r.colors map1 color=bcyr -ae"
 G> valgrind -v --tool=memcheck --leak-check=yes  $CMD
 ==7130== Memcheck, a memory error detector.
 ==7130== Copyright (C) 2002-2006, and GNU GPL'd, by Julian Seward et al.
 ==7130== Using LibVEX rev 1658, a library for dynamic binary translation.
 ==7130== Copyright (C) 2004-2006, and GNU GPL'd, by OpenWorks LLP.
 ==7130== Using valgrind-3.2.1-Debian, a dynamic binary instrumentation
 framework.
 ==7130== Copyright (C) 2000-2006, and GNU GPL'd, by Julian Seward et al.
 ==7130==
 --7130-- Command line
 --7130--    r.colors
 --7130--    map1
 --7130--    color=bcyr
 --7130--    -ae
 --7130-- Startup, with flags:
 --7130--    -v
 --7130--    --tool=memcheck
 --7130--    --leak-check=yes
 --7130-- Contents of /proc/version:
 --7130--   Linux version 2.6.26-bpo.1-686 (Debian 2.6.26-13~bpo40+1)
 (nobse at debian.org) (gcc version 4.1.2 20061115 (prerelease) (Debian
 4.1.1-21)) #1 SMP Mon Jan 12 20:06:26 UTC 2009
 --7130-- Arch and hwcaps: X86, x86-sse1-sse2
 --7130-- Valgrind library directory: /usr/lib/valgrind
 --7130-- Reading syms from /lib/ld-2.3.6.so (0x4000000)
 --7130-- Reading debug info from /lib/ld-2.3.6.so...
 --7130-- ... CRC mismatch (computed A2342EFB wanted 8FC9FDDB)
 --7130--    object doesn't have a symbol table
 --7130-- Reading syms from /usr/local/src/grass/svn/grass65/dist.i686-pc-
 linux-gnu/bin/r.colors (0x8048000)
 --7130-- Reading syms from /usr/lib/valgrind/x86-linux/memcheck
 (0x38000000)
 --7130--    object doesn't have a dynamic symbol table
 --7130-- Reading suppressions file: /usr/lib/valgrind/default.supp
 --7130-- Reading syms from /usr/lib/valgrind/x86-linux/vgpreload_core.so
 (0x4019000)
 linux/vgpreload_memcheck.so (0x401B000)
 linux-gnu/lib/libgrass_gis.6.5.svn.so (0x4021000)
 linux-gnu/lib/libgrass_datetime.6.5.svn.so (0x407A000)
 --7130-- Reading syms from /usr/lib/libz.so.1.2.3 (0x409C000)
 --7130-- Reading syms from /lib/tls/i686/cmov/libm-2.3.6.so (0x40B0000)
 --7130-- Reading debug info from /lib/tls/i686/cmov/libm-2.3.6.so...
 --7130-- ... CRC mismatch (computed 70BA299D wanted 3AF3BB73)
 --7130-- Reading syms from /lib/tls/i686/cmov/libc-2.3.6.so (0x40D5000)
 --7130-- Reading debug info from /lib/tls/i686/cmov/libc-2.3.6.so...
 --7130-- ... CRC mismatch (computed B308380A wanted ED81AE67)
 --7130-- Reading syms from /lib/tls/i686/cmov/libdl-2.3.6.so (0x4206000)
 --7130-- Reading debug info from /lib/tls/i686/cmov/libdl-2.3.6.so...
 --7130-- ... CRC mismatch (computed DE27AFD0 wanted AA9202FA)
 --7130-- REDIR: 0x41407F0 (rindex) redirected to 0x401DF30 (rindex)
 --7130-- REDIR: 0x413C970 (malloc) redirected to 0x401D306 (malloc)
 --7130-- REDIR: 0x413FF30 (strcpy) redirected to 0x401E970 (strcpy)
 --7130-- REDIR: 0x413A6B0 (free) redirected to 0x401CF20 (free)
 --7130-- REDIR: 0x413FEC0 (strcmp) redirected to 0x401E2D0 (strcmp)
 --7130-- REDIR: 0x4140430 (strlen) redirected to 0x401E200 (strlen)
 --7130-- REDIR: 0x4140640 (strncmp) redirected to 0x401E260 (strncmp)
 --7130-- REDIR: 0x413CD90 (realloc) redirected to 0x401D3B5 (realloc)
 --7130-- REDIR: 0x4141610 (memmove) redirected to 0x401E520 (memmove)
 --7130-- REDIR: 0x4141B20 (memcpy) redirected to 0x401EBE0 (memcpy)
 --7130-- REDIR: 0x413C630 (calloc) redirected to 0x401C633 (calloc)
 --7130-- REDIR: 0x413FD50 (index) redirected to 0x401E020 (index)
 --7130-- REDIR: 0x413FBA0 (strcat) redirected to 0x401E5E0 (strcat)
 --7130-- REDIR: 0x4141180 (memchr) redirected to 0x401E3F0 (memchr)
 --7130-- REDIR: 0x41423C0 (rawmemchr) redirected to 0x401E5C0 (rawmemchr)
 --7130-- REDIR: 0x4141680 (memset) redirected to 0x401E4F0 (memset)
 ==7130== Invalid read of size 4
 ==7130==    at 0x804B320: get_fp_stats (stats.c:129)
 ==7130==    by 0x804A654: main (main.c:385)
 ==7130==  Address 0x4223EDC is 12 bytes before a block of size 4,000
 alloc'd
 ==7130==    at 0x401C6CA: calloc (vg_replace_malloc.c:279)
 ==7130==    by 0x402EC00: G__calloc (alloc.c:74)
 ==7130==    by 0x804B1B6: get_fp_stats (stats.c:101)
 ==7130==
 ==7130== Invalid write of size 4
 ==7130==    at 0x804B325: get_fp_stats (stats.c:129)
 alloc'd
   72%
 valgrind: m_mallocfree.c:194 (get_bszB_as_is): Assertion 'bszB_lo ==
 bszB_hi' failed.
 valgrind: Heap block lo/hi size mismatch: lo = 5120, hi = 5161.
 Probably caused by overrunning/underrunning a heap block's bounds.
 ==7130==    at 0x38016993: report_and_quit (m_libcassert.c:136)
 ==7130==    by 0x38016CBF: vgPlain_assert_fail (m_libcassert.c:200)
 ==7130==    by 0x3802049E: vgPlain_arena_free (m_mallocfree.c:191)
 ==7130==    by 0x38036001: vgPlain_cli_free (replacemalloc_core.c:108)
 ==7130==    by 0x380019DB: die_and_free_mem (mc_malloc_wrappers.c:111)
 ==7130==    by 0x38036782: do_client_request (scheduler.c:1158)
 ==7130==    by 0x380380A0: vgPlain_scheduler (scheduler.c:869)
 ==7130==    by 0x38057012: run_a_thread_NORETURN (syswrap-linux.c:87)
 sched status:
   running_tid=1
 Thread 1: status = VgTs_Runnable
 ==7130==    at 0x401CFA5: free (vg_replace_malloc.c:233)
 ==7130==    by 0x402ECD5: G_free (alloc.c:129)
 ==7130==    by 0x403F248: G_zlib_read (flate.c:190)
 ==7130==    by 0x4043E3A: read_data_fp_compressed (get_row.c:115)
 ==7130==    by 0x40442D0: read_data (get_row.c:238)
 ==7130==    by 0x4044F40: get_map_row_nomask (get_row.c:616)
 ==7130==    by 0x4045047: get_map_row_no_reclass (get_row.c:646)
 ==7130==    by 0x4045140: get_map_row (get_row.c:678)
 ==7130==    by 0x404538E: G_get_raster_row (get_row.c:898)
 ==7130==    by 0x4045435: G_get_d_raster_row (get_row.c:968)
 ==7130==    by 0x804B229: get_fp_stats (stats.c:109)
 Note: see also the FAQ.txt in the source distribution.
 It contains workarounds to several common problems.
 If that doesn't help, please report this bug to: www.valgrind.org
 In the bug report, send all the above text, the valgrind
 version, and what Linux distro you are using.  Thanks.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/565#comment:1>
