[GRASS-dev] Re: [GRASS GIS] #565: r.colors: glibc double free or
corruption with -ae
trac at osgeo.org
Tue Apr 21 06:59:32 EDT 2009
#565: r.colors: glibc double free or corruption with -ae
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.5.0
Component: Raster | Version: svn-develbranch6
Resolution: | Keywords: r.colors
Platform: Linux | Cpu: x86-32
Comment (by hamish):
..., even with maps created with the same params which do run to 100% on
the standard command line will barf in valgrind at the same 72% complete
stage.
Same if I do 'g.region -d' first, so that's probably a red herring (I
mentioned it because the volcano alg calcs distance from the map center so
you can get an div0 anomaly there if the cells line up).
I can simplify the map creation line to:
r.surf.volcano -r map3
and it still breaks with valgrind. If I remove the `-r` rough-it-up flag
(which sends the surface slightly negative) the min becomes 1.2345e-91 and
valgrind runs to completion. it still complains about the same "Invalid
read of size 4" and "Invalid write of size 4" errors though.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/565#comment:2>
