[GRASS-dev] Re: [GRASS GIS] #456: Undefined references when
building grass 6.4 rc4
trac at osgeo.org
Wed Apr 22 06:49:16 EDT 2009
#456: Undefined references when building grass 6.4 rc4
Reporter: fundawang | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: reopened
Priority: major | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Resolution: | Keywords:
Platform: Linux | Cpu: x86-64
Comment (by glynn):
Replying to [comment:20 hamish]:
> > I've found a new underlinking problem with cairo:
> > http://svn.mandriva.com/cgi-
bin/viewvc.cgi/packages/cooker/grass/current/SOURCES/grass-6.4.0-linkage.patch
Saying "I've found a problem" then not actually saying what the problem is
doesn't help anyone.
-EXTRA_LIBS=$(DRIVERLIB) $(GISLIB) $(CAIROLIB)
+EXTRA_LIBS=$(DRIVERLIB) $(GISLIB) $(CAIROLIB) $(XLIB)
The above is bogus; $(CAIROLIB) should already contain all of the
necessary linking switches. If it doesn't, configure.in should be modified
to set CAIROLIB correctly.
Ticket URL: <https://trac.osgeo.org/grass/ticket/456#comment:21>
