[GRASS-dev] problem with required variables (shell script / grass6.4)
Hamish hamish_b at yahoo.com
Thu Apr 23 05:40:06 EDT 2009
roberto marzocchi wrote:
> I have a problem with a script, that
> I've  written for GRASS 6.3
> When I use it in GRASS 6.4, the script don't start,
> because it don't recognize 3 of 4 required inputs.
> This is the error message:
> "ERROR: Required parameter <NAME_INPUT> not
> set:"
> But the input is correctly set.
> Anyone understand the reason?
there is some problem in the newer code that the parser is rejecting
upper case options names. I don't know why, but we should fix that.
Hamish
