[GRASS-dev] r.surf.fractal [was: v.buffer]
Paolo Cavallini
cavallini at faunalia.it
Thu Apr 23 10:30:10 EDT 2009
Hamish ha scritto:
>> Hamish ha scritto:
>>> no? what is the exact error message?
> Paolo:
>> option d not recognized
> Using grep I can not find any trace of that message in the latest qgis
> trunk/ SVN or GRASS's libgis. Has it been retranslated?
Sorry, it may be slightly different: I do not have a qgis1.x+grass64
machine at hand now, so I cannot check.
> does QGIS's grass toolbox double-check the module options using the 'g.module --interface-description' or does it just try to run what the programmer/user threw at it and see what happens?
Dunno. When a module is called, if an option is not present, it throws
an error, so it seems the first of the two options.
Thanks.
Paolo Cavallini: http://www.faunalia.it/pc
