[GRASS-dev] terminology issues in grass7
Michael Barton
michael.barton at asu.edu
Mon Apr 27 00:46:49 EDT 2009
I added my 2cents worth to the WIKI
Michael
____________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
On Apr 26, 2009, at 4:01 PM, Martin Landa wrote:
> Hi,
> 2008/8/11 Maciej Sieczka <tutey at o2.pl>:
>> (A "table" is an object in the database that stores the given
>> "layer"'s
>> attributes, and the "table" and "layer"'s geometrical features are
>> linked using "key column" in which the "categories" are stored inside
>> the "table".)
>> Regarding Moritz's remark I indeed missed the fact that the vector
>> map
>> having 0 or more "layers" does not directly imply it has the same
>> number
>> of data "tables". Given that, "table link" to replace "layer" as I
>> suggested is bad. If we are to change the term, we should do it
>> right.
>> How do you like "category set" then, "catset" in short? Together with
>> with replacing term vector "map" with vector "layer" it would yield:
>> Each vector "feature" (line, point etc.) can have 0 or more
>> "categories"
>> in a vector "layer". Each "category" belongs to only 1 "category
>> set".
>> Each "category set" of a vector "layer" can be connected or not
>> with a
>> single database "table". The "key column" in that "table" stores the
>> "categories" of "features" present in the given "category set".
> after some time I am going to re-open this topic... I have summarized
> the proposals on the wiki
> http://grass.osgeo.org/wiki/GRASS_7_Terminology#Vector_layer
> From my point of view, I would suggest to use "category set" (catset)
> as replacement for 'layer'.
> Please feel free to put here your suggestions. It would be good to
> close this topic soon. Then I can start changing terminology in GRASS
> 7.
> Best regards, Martin
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
