[GRASS-dev] Re: [GRASS GIS] #570: startup problem with standalone GRASS install
GRASS GIS trac at osgeo.org
Tue Apr 28 23:40:24 EDT 2009
  Reporter:  timmie        |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  normal        |   Milestone:  6.4.0
 Component:  Installation  |     Version:  6.4.0 RCs
Resolution:                |    Keywords:
  Platform:  MSWindows XP  |         Cpu:  Unspecified
Changes (by hamish):
  * component:  default => Installation
Comment:
 I expect an incompatibility with the PythonXY installation.
 (ie pyXY is built without some needed library function)
 can you install a secondary python install (generic 2.5) to run with
 grass?
 what version of pythonXY? is it supposed to be a full python install +
 scientific tools, or has it dumped normal python things it thinks a
 scientist won't use?
 from the dos box screenshot it looks like you try with grass 6.4.0rc4.
 can you translate the error messages into english for those of us  too
 ignorant to understand?
 cheers,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/570#comment:3>
