[GRASS-dev] Re: [GRASS GIS] #570: startup problem with standalone
GRASS install
trac at osgeo.org
Wed Apr 29 04:43:12 EDT 2009
#570: startup problem with standalone GRASS install
Reporter: timmie | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Installation | Version: 6.4.0 RCs
Resolution: | Keywords:
Platform: MSWindows XP | Cpu: x86-32
Changes (by timmie):
* cpu: Unspecified => x86-32
Comment:
> I expect an incompatibility with the PythonXY installation. (ie pyXY is
built without some needed library function)
You may have a look at the standard plugins of PythonXY here:
http://www.pythonxy.com/standard.php
It's really neat for straight off installation for science.
> can you install a secondary python install (generic 2.5) to run with
grass?
Just bare Python 2.5?
I can try as long as it does not spoil my sys.path
More an more FOSS programs have python. On windows, everyone installs its
own version of python into the programs directory...
> what version of pythonXY?
latest. 2.1.12
> is it supposed to be a full python install + scientific tools,
Yes.
> or has it dumped normal python things it thinks a scientist won't use?
I don't think so.
> from the dos box screenshot it looks like you try with grass 6.4.0rc4.
Yes. from the standalone installer.
> can you translate the error messages into english for those of us too
ignorant to understand?
I will try:
https://trac.osgeo.org/grass/attachment/ticket/570/bug_grass.jpg
=> prozedureinsprungspunkt: starting point of procedure
=> wurde in der DLL [...] nicht gefunden : was not found in the DLL [...]
https://trac.osgeo.org/grass/attachment/ticket/570/bug_grass2.jpg
=> DLL Load failed: Die angegebene Prozedur wurde nicht gefunden : DLL
Load failed: the procedure called was not found
Is there a list of python modules that are required for GRASS to run?
Ticket URL: <https://trac.osgeo.org/grass/ticket/570#comment:4>
