Glynn Clements wrote: > > Ah, ok, you use the grass57 dataset. I have now changed the version > > number and compatibility info, you should now get reasonable > > warnings/errors with the spearfish57 dataset. > > Okay, I'll check it. Nope. As of r38644, the error message is unchanged. -- Glynn Clements <glynn at gclements.plus.com>
